I inherited a 140 OTS, 1956, dual exhaust. Also a 1961 MKII 3.8 with red "C" head cast & C valve covers. I wonder if heads were switched by my father at some time.Both have H6 Carbs
A restoration specialist indicated I should switch heads with C to the 140 to make it an MC Roadster. Does this make economic sense? Would C head substantially increase value of 140? Both engines run well after carb rebuilds.
Curt
Submitted by SE98-32482CJ on Sun, 12/12/2010 - 09:59
Curt do the serial numbers match the engines? In other words if you think your father switched them they should match the other car. Putting a "C" head on the 140 if it did not come with a c head would be recognized and might add a bit of value but how much would be difficult to determine.
