I need to change my timing tensioners. do I need to remove the heads? I'm planning on changing the water pump, timing chain, seal while I'm in there. is there anything else I need to do? any tips, suggestions etc on doing the job? any manuals that explain how to do the job?
thanks dave1
1992 xjs v12
Submitted by bonnettoboot@e… on Wed, 09/10/2014 - 12:30
Submitted by bsem@comcast.net on Wed, 09/10/2014 - 11:39
replace timing tensioners
I'm replacing the tensioners because It started to make a noise and I took it to a jaguar mechanic who said that is what it needed.
Submitted by bonnettoboot@e… on Tue, 09/09/2014 - 22:42
It is a lot of work and you may find that you have to go deeper, why are you replaceing the tensioners?
get at least one more diagnosis!
