I have just poured a new concrete slab on my garage floor. What is the best type of coating to put on the floor so the enevitable oil drips can be easily cleaned up?
Submitted by bonnettoboot@e… on Mon, 09/20/2010 - 21:58
I purchased an epoxy (2 stage) paint 5 years ago. I pressure washed let dry for two days and applied it, I am surpised at how well it has held up. There are also marble like finishes (non slip) that can be applied professionally.
Submitted by SW07-04436CJ on Mon, 09/20/2010 - 21:43
David,
I have used the gray garage floor paint supplied by Griots Garage and the stuff from Home Depot. Both say the garage floor should cure for 4 to 6 months. Frustrating I know but you do not want to trap water in there. The Home Depot stuff also says you cannot paint if the morning temperature is below 60 degrees.
I put plastic down for the Colorado winter and painted it in May. Be sure to use one single sheet of thick plastic and tape down the corners. If you use a double sheet, you can slip on it just like ice.
Also, for the Home Depot stuff, I use the mild acid wash they include. It is necessary to give the concrete some Tooth. Then I power wash the floor once, sometimes twice.
I have now done 8 of these floors using the Home Depot stuff. I do not recommend the Sprinkles, just the tan or gray paint. Also keep a wet roller or you will see roller marks when the paint dries. If you want more details, contact me. Oh, the carolinas are too far to go for a service call.
Steve Kennedy
Denver
