Am having air conditioning unit converted because told parts not availble. being done by Ccoventry Motors Pickering Ontario Jag dealer with Jag parts. Will I lose any points in Concours Championship class because of this conversion?
BAKER & COLE
Barristers and Solicitors
8 Bridge Street
Lakefield Ontario
k0l2h0
Submitted by c.roberts@symp… on Thu, 05/31/2007 - 10:09
Submitted by dougdwyer1@com… on Thu, 05/31/2007 - 09:25
conversion by jag dealer of air conditioning unit on 1989 xj-s
I presume you are talking about changing from R12 refrigerant to R134a.
Except for slightly different fittings screwed onto the charging ports...which only a very sharp judge would notice... the conversion should be invisible.
I don't know if there is anything in the Concours handbook to address this issue...probably not. I wouldn't give it a second thought but let's wait for some judges to chime in and hear what they have to say.
Doug Dwyer
Longview Washington USA
1995 XJR
Doug:
I think that switching from R12 to R134a, with the change in the ports, is allowed, as this is a legislated requirement, just as the addition of seat belts to older cars is required in some jurisdictions, and possibly the addition of the third stop light, and daytime head lights on, in some Canadian jurisdictions.
If it is for some/one of the physical components that are being changed, then if you can show/document that the change is the official part number change from Jaguar, then this is allowed as well for Championship class. If the judge cannot see the change, such as a change in the evaporator, then it is a moot point.
Mark Roberts, Ottawa Jaguar Club
