Need instructions on how to remove and repair headlamp assembly to remove moisture inside housing.
Submitted by svillante@gmail.com on Fri, 06/20/2014 - 18:37
I removed the moisture by inserting a small air hose from my compressor into the rear of the headlight assembly. After about an hour the water evaporated. I no longer go through a car wash. That was the cause of the water entering the assembly.
