New lister and brand new owner of a very fine original 1953 XK120 coupe. First day the fuel pump quit. (seller will replace, but) First, I can't find the fuel pump. Just EXACTLY where is it? Secondly, If I locate it and remove it, does the thing have "points" in it that can be cleaned? Seems like in the far recesses of my mind I remember something like that. The car is for bragging and fun, not concours. so Can I put an electronic fuel pump in it? Any sage advice will be appreciated.
2002 XK8, 1953 XK120
Submitted by jbansley@sbcgl… on Wed, 02/22/2006 - 15:46
Submitted by SW03-09811 on Wed, 02/22/2006 - 00:15
XK120 fuel pumps
Jim,
If you haven't yet removed your pump, you'll discover that, if the supply line from the tank is full of fuel, when it's disconected from the pump, it will form a siphon that will drain the tank if the line is not plugged. When you do disconnect it, be ready with both a catch pan and a tapered plug to avoid a last minute scramble and a large amount of fuel down your sleeve and on the floor.
The post by Otto gives you a good idea what the set up generally looks like. A caution, however, is that addition of the filter and its hose connectors (without some sort of protective shield) can present a substantial fire hazard if the car runs over an obstruction that strikes and causes any one of those hoses to disconnect.
Good luck,
Dick Cavicke
Submitted by NE08-63766 on Tue, 02/21/2006 - 19:29
XK120 fuel pumps
Jim,
On the right side, under the door, look at the frame & you should see what looks like this. The bracket behind is for the 150S 2nd fuel pump. Yours has only one bracket.
Regards, Otto M. -58 XK-150fhc, S-834292DN
Submitted by mcfoo@columbus… on Tue, 02/21/2006 - 14:00
XK120 fuel pumps
Fuel pump is just behind the main frame crossmember on the right side. You can replace it with anything you like, as long as it is positive ground.
Hi John, Otto and Dick. Much appreciated input. I see that this list is right on. As I get more familiar with the old girl, I'll likely be asking more dumb questions. Thanks.
Jim
2002 XK8,
1953 XK120
