Greetings! I have an ID number question!
Is there more than one location on the transmission where one can find its ID number?
(also stamped in the engine compartment VIN plate)
I know the circular port on the top cover has the numbers stamped in the circle, but Im guessing they are duplicated somehere else on the transmission. I dont want to take apart the interior to find the number!
Does any one know?
Do the overdrive units have ID numbers as well?
Thank you!
gregnfc
NYC
Submitted by SE98-32482CJ on Sat, 03/31/2012 - 06:03
Greg the numbers are also on the case of the trans but that is also difficult to see. The OD units do have a SN.
