I'm in the process of installing a new wiring harness.(1965 E-Type Roadster) After enlarging the diagram 200% I'm ready to start! Could someone indicate the numbers assigned to the fuses in the center dash so I could match to the wiring diagram? Took photos of wiring before I removed it but I would like to trace all circuits within reason. Is there additional information that would help me?
Richard Sabonis
#10018
Submitted by wcjssj@comcast.net on Tue, 03/20/2007 - 02:37
On my 67 E-type that has an alternator the fuses are numbered beginning in the upper left hand corner and going down: 1, 2, 3, 4. Then on the right starting at the top: 5, 6, 7, 8. 1 and 2 are the headlites; 3 and 8 are always hot and have the purple wires; 3 is the horn; 4 is not used; 5 has sidelamps, taillites, edgelites, panellites; 6 has the horn relay, radiator fan, washer, stop lites; 7 has the wiper motor and all the electronic gauges, heater motor, turn signals, reverse; 8 has the cigar liter, interior, map, clock; the fuel pump and coil are not fused.
Hope yours is the same and this helps. Good luck. 1967 E-type S1 FHC
