I think the antenna should be found attached to the body, under the trim that lines the convertible hood stowage well. Wrestle the trim out from under the top of the rear seat and the two shoulder belt trim escutcheons, and the whole panel will pull out. That should expose the NAV antenna.
Good luck!
Submitted by rgrisar@hotmail.com on Mon, 02/22/2016 - 17:04
Hello all. I hope that Steven Petry reads this. sold the 71 XKE and 95 XJS. Bought a 2001 XKR. You (Steven) helped me find the GPS antenna last year. Replaced and NAV system works great. Thanks again. Cleaned the MAF sensor, reset the codes. Now get only P1647 and a pending P1000. Nothing seems to get the pending code to clear. Any ideas?
