I am re-installing my rebuilt water pump. Should I, or is it even possible to, have the pulleys installed prior to installing the pump?? It looks as if the lower two bolts would have severly limited access for installation.
Any one able to offer advice or an installation sequence I could follow.
Thank you all.
Submitted by wmcwings@att.net on Fri, 03/01/2013 - 17:27
Submitted by wmcwings@att.net on Thu, 02/21/2013 - 20:26
Water pump install questions
Tom,
Thank you. I take it isn't possible to install with the pulleys attached?
The problem I ran into is trying to align the bolt holes for the pump pulley and the alternator pulley after the pump is installed.
Charlie
Submitted by coventryclassi… on Wed, 02/20/2013 - 09:13
Charles;
Installed pully off.
Cheers Tom
Got it! Thanks guys.
