Does anybody run a V-12 E-Type without the rain shields?
It appears that the only real reason for them is to keep water out of the spark plug recesses.
Comments gentlemen?
1972 Series III 2+2
Submitted by NE52-32043 on Wed, 10/19/2005 - 13:57
Tom,
I ran my old '72 2+2 for a while without the shields. Then it rained. I put them back on. Without them, the V becomes a swimming pool. If they are not in great shape, you can get new ones from SNG Barratt.
As far as the filter element goes, check SNG Barratt or Moss Motors. I used to buy mine from SNG Barratt. They always had them in stock, no problem, and they were reasonably priced.
Steve Weinstein
former '72 E-type 2+2 owner
'70 XKE FHC, '69 XKE OTS
Submitted by tomconnors@ear… on Tue, 10/18/2005 - 20:31
Negative on the misunderstanding. Filter elements no longer available.
Rain shields removed. They are now in the crate with all the other superflurous hardware. now I can see my vacuum lines etc. for mtc.and cleaning.
Tom
1972 Series III 2+2
Submitted by pascal@jcna.com on Tue, 10/18/2005 - 18:08
well, i don't see what you gain by removing them. they're not in the way of anything and don't weight much... Jaguar added them after some wet weather testing, so i guess they didn't add them for no reason. I didn't have any problems when i didn't have them but in all honesty i don't think the car sat out in the rain much.
re oil element, i don't have any recent invoice handy, but the last one i have (a year ago) showed 26.10. must be a misunderstanding, he usually charges me about $100 to change the oil, top off the tranny and diff, lube everything, and give the car a good inspection.
Pascal Gademer
Submitted by tomconnors@ear… on Tue, 10/18/2005 - 17:28
The thing is, they are fitted. I would like to remove them and don't see why I shouldn't.
By the way Pascal, Jag Doctor (Boca) want's $75.00 for an oil filter element. Welsh told me today they were out-of-stock due to the manufacturer has a "tooling problem".
1972 Series III 2+2
Submitted by pascal@jcna.com on Tue, 10/18/2005 - 17:07
i ran mine without for a couple of years, no problems even in our typical florida downpours.
i don't see any reasons not to have them, they're easy to find (or were...) but if you don't have them for a while, don't worry.
Pascal
00 XKR Coupe (for sale)
72 XKE 2+2
