That port is supposed to be open. That is the port for the pump to exhaust the air it 'vacuums' out of the actuator that pulls the throttle. Just be sure the vacuum hose is not on the wrong port. THe cruise sure won't work then. I've seen that happen two or three times.
Good luck!
