I took the 4 carbs off my 74 xke and rebuilt them. When I turn the ignition on and the fuel pump runs, gas pours out along the seam where the 2 halves match up and bolt on with the air cleaner. It is the parts that have a pipe that connects the 2 U shaped pieces on the top of the carb when looking from inside the air cleaner with the filter out. The 2 U shaped pieces bolt together, and I have either hooked something up wrong or there should be a gasket between the 2 halves. I have looked at the service manual but it is not well pictured.
Thanks for your help, Jerry Nutt
