need help please my rear rt hand rear window does not come up the left side is working fine i did switch relays to see if it was that and did not do any good is there a fuse or bearker that could be the cause also where is the term. breaker and could that be the problem if i cannot get the window up is there any way i can pull it up i would gateful foe any help thank you
Submitted by crhorneff@aol.com on Tue, 09/13/2011 - 17:06
Submitted by crhorneff@aol.com on Tue, 09/13/2011 - 14:45
right rear window does not operate
i recyced at leasr 5 times still window will not come up
Submitted by crhorneff@aol.com on Tue, 09/13/2011 - 13:57
sorry it is a 1989 xjs i did switch the change over relay with another one to see if that was it it was not the one you are talking about that was located in the right side with the other relays that were left quarter down left quarter up conv top up conv top down right quarter down right quarter up i did removed the left quarter up relay and exchanged it with the right quarter up relay to see if that was the problem the left window still came up and the right one did not i will try to cycling it again and see what happens any more infor would be helpful thank you l
Submitted by SE98-32482CJ on Tue, 09/13/2011 - 13:43
Bob it would help if we knew the year and if it is a Jaguar top or a Hess top. The Hess top cars had seperate controls for the quarter glass. The Jaguar cars are automatic and the most frequent cause is that the top cycle was interupted and the car is confused. Try cycling your top a couple of times full open and full close including locking it. If that does not result in success check the relay in the rear parcel shelf area.
spayed the relays with a cleaner and connections recyce once again window came up thanks for all your help
