My rear view mirror is leaking fluid which causes stains in the mirror. How difficult is it to either fix or replace the mirror?
Submitted by joshbartlett@r… on Sun, 06/22/2014 - 18:37
Submitted by stevejag@sbcgl… on Sat, 06/21/2014 - 01:20
Rear View Mirror
Here is an outfit that will repair your mirror with a gel filled mirror for about 100 bucks plus your shipping to them.
Sybesma's Electronics
581 Ottawa Ave Ste 100
Holland, MI 49423
USA
800-456-4265
Send a note to Stacy at 'orders
sybesmas.com '. She will give you the lowdown on how and where to ship the mirror. Turn around time has been about three days usually.
Submitted by svillante@gmail.com on Fri, 06/20/2014 - 18:33
Rear View Mirror
Thanks, Bill, but I'm referencing the interior rear view mirror, not the side mirrors.
Submitted by wpritchard2@tx… on Fri, 06/20/2014 - 17:33
Rear View Mirror
I replaced the mirror from eBay for $100 to $150. remove all the screws on door panel, pop it off and the mirror is held on with 3 10mm bolts. The whole thing took 30 minutes. There are 2 screws with plastic covers. A trim removal tool helps
I used Sybesma's and they did as they said they would, at the price and time frame they agreed to.....
I did have to laugh; It used to be said that the British couldn't make a good car radio because they couldn't figure out how to get it to leak oil.... It appears that Jag. has figured out a way to make the mirror leak oil.
Rule Britannia!
Josh Bartlett
1969 E-type,
1997 XK-8
1937 Packard 115
