What is the best position to drill a hole in the right rear sill end panel (16-2021) to inspect the right sill?
-- need to see past the front and rear inner sill stiffeners (16-2020 and 16-2019)
-- can you please provide measurements
Wish to clean out, spray rust preventer and waxoyl
I have only one inspection 7/8" hole in the right inter sill 16-2015RH behind the cross member 16-2025
What size hole to do you recommend?
What did you use to plug the hole?
Do you have any other suggestions?
I have a camera with a 17MM head or 0.67 inches
John
![](https://www.jcna.com/sites/default/files/rear%20sill%20end.jpg)
Submitted by jlynch10@yahoo.com on Sat, 09/12/2015 - 23:49
Submitted by jlynch10@yahoo.com on Thu, 09/24/2015 - 02:32
In reply to Rear Sill End Panel where to drill hole to inspect the sills v2 by jlynch10@yahoo.com
Check the attached photo for suggested location of sill closing panel where to drill inspection holes
![](https://www.jcna.com/sites/default/files/closing%20sill%20drill%20holes_0.jpg)
John
