Unless you have a larger lead or brass/ copper hammer (watch that fender when you swing!) try this----set your removal tool so that a floor jack can be placed in play with the force of the jack applied toward a "remove" arm of the tool. place as much pressure as you can without lifting the car off the ground and then attack one of the other arms--works every time but again---"Watch that fender"!
