Edited on 2007-01-12 4:18:07
purchased my 1997 XJ6L jAUGUAR in 2002 and the only dissapointment has been the constant annoyance of the check engine light activating. The records from its birth into the world has shown this problem existing due to a knock sensor, which has been changed numerous times. Has any fellow owners encountered the same problem? My mechanic just checks to make sure nothing is wrong and deactivates the light, which will eventually activate again.
Submitted by SE21-33540J on Fri, 01/12/2007 - 09:37
Daniel,
I think I replied to this once before. Have the Catalytic converter checked. I have a friend with the same problem on a 1996 and did the same things you are doing and in the end it was the catalytic converter.
Jerry
1986 XJ-SC 3.6 / 5 Speed
2006 S-type R
