Edited on 2007-06-14 21:43:47
A fuse is continually blowing and I get the following messages:
Suspension Fault & Electrical Fault
I was told by the Jag Dealer mechanic that this model does NOT have a suspension sensor, and therefore the problem must be eslewere. The mechanic thinks it is in the wiring harness under the seat. He took out the seats reconnected all of the connextions. The fuse continues to blow.
I have had the car in twice and have gone through atleast 10 fuses. Now I don't change the fuse. This fuse also controls the cruse control. I really miss this. This has been going on for about 3 months.
This all started when I backed up over a small snowbank. That is why I thought it was a suspension problem (mechanic says no way).
Any ideas? Thanks
Joe
