Edited on 2009-07-11 18:31:40
Hello All,
I am about to replace the yellowed fan blade on my 1990 XJS. I have been told it is possible to get the old one out without removing the shroud. I am skeptical & think it will require more than just removing the bolts and replacing. Any words of wisdom?
Dwight
Submitted by mghirsch@netzero.net on Tue, 07/14/2009 - 17:33
The way I did it was to remove the fan and the clutch as a unit. I then replaced the fan and reinstalled the clutch/fan unit.
One hint,. Get nylock nuts. The little factory lockwashers are kind of tricky to put on and keep on while working the nuts.
