Tech reported error with road test staility control (test C1095) internal fault in pump motor. Has anyone had this problem, and what correction can be taken?
Submitted by stevejag@sbcgl… on Mon, 02/21/2011 - 13:31
Search the forum and you will find help on removing the ABS Module to open it and repair broken solder joints. Not a bad repair, just takes a little finesse.
