Who knows which generator and PAS pump I can use for my XJ power assisted steering rack on my MK2. I prefer to couple a generator direct with the PAS pump instead of an extra drive pulley. I heard from a Hitachi generator with a ? pump.Turning or welding parts is no problem.
Submitted by mortoncjc@mind… on Wed, 07/02/2008 - 16:30
Roger
This is not my strong area. I'd check Coventry West, XKs, etc for a conversion kit. XKs has a rack and pinion kit so they may have the answer.
I remember that a few alternators were built for compact diesel vehicles with a thru shaft to drive a rear-mount vacuum pump for power brakes. I'm thinking Nissan or VW. That's what you want, and you make a mounting face plate.
Good luck.
Jim
Submitted by rme@moba.nl on Wed, 07/02/2008 - 05:58
Jim ,thanks for your answer. Its in fact what I meant as I made a mistake : I am searching for a PAS pump direct mounted on the alternator. Alternative a separate Alternator and PAS pump. Which models do fit with some DIY?
