There will be a short article in the next Jaguar Journal addressing a topic that has come up from time to time and on the tech line a lot. How to obtain factory manuals and books for your Jaguar from the 1980s to 2001. JCNA has worked with JaguarLandrover to fix this situation and you are now able to order new factory books directly and not have to hunt part numbers and attempt to obtain them via a dealer or worse hope the EBay item you are bidding on is the correct one. JCNA members should be able to go to www.helminc.com and select the vechicle owner/do-it-yourself option and look at their stock. If you select all years/ all models you can see everything in stock. It is then up to you to order and pay. In this case there was no method to put it in the shoppe and no room which you will understand when you see the prices. Good luck and good hunting obtaining all the goodies that came with your car. Of course for older models the JCNA shoppe is still the place to go. Happy Holidays to all.
2001 and later are available via Jaguar electronically--see their link here and go to owner support.
