I am hoping for some comments as to what I need to do next.
My series 2 OtS had trans leak at the bell housing oil seal. Oil got on the clutch, pressure plate and fly wheel. See pics of fly wheel. I have replacement clutch friction plate, and pressure plate. I am concerned about the fly wheel.
I clean as best I could with brake cleaner but the black areas do not come clean. What I can gather is that they are a mix of burnt oil and areas of the fly wheel surface that has been heated more than others.
I am thinking of using 400 grit sand paper and sand it gently and hopefully the surface burnt oil areas will be removed. Or do I need a professional resurfacing?
Any suggestions are much appreciated.
Submitted by MikeEck@optonl… on Sat, 03/22/2014 - 14:41
Submitted by m.giuliani@sym… on Sat, 03/22/2014 - 14:04
Now is the best time to resurface your flywheel. It's an inexpensive procedure and will give you the highest likelihood of the clutch working properly when it's assembled.
