I found broken wires between the ignition amplifier and the distributor, pretty normal I'm told. The issue is, when I was re-working the wiring I cut off the damaged two wire plug coming from the pick-up, I no longer have it. the connectors protuding from the amplifier, one is small & one is large, the small one becomes the red wire, the large blue. The red wire is the male on the connector to the pick-up,the pick-up wires are not red & blue, Question: what pick-up wire does the red wire connect to (burnt orange or burnt brown)?
