My MK1 sender is bad.I can find no sender.I can get a MK2 universal type sender tho.Will it fit,be compatible with my gauge? Anybody solved this problem? Thanks.
Submitted by SE98-32482CJ on Wed, 11/30/2011 - 13:41
Tom on the back of the gauge you will find a cork plug(s). They allow you to adjust the arm with a fine blade between two points. If it were me I think I would just fill her up and record what the readings are. You know full is full and empty is empty. The first is not an issue--just the latter! Good luck.
Submitted by britrep@juno.com on Wed, 11/30/2011 - 13:08
Thanks George, you always come thru. Now the next question,how do I calibrate the gauge? There are 2 very small nuts on the gauge. Are they the secret? I'd be afraid to tear it apart. The insides look pretty fragile, thanks
