I’ve been upgrading the lighting on my 95. The turn signal lights are hyper flashing and need to be connected to a resistor which should be connected to a ground.
There are 2 wires coming from the bulb connector the striped wire I sure should be connected to one side of the relay. The other wire is black. this most likely
the ground wire. Should I connect the other side of the resistor to this or should I connect it to the metal innerbody
