I just registered with JCNA as a new 1968 Jag E-Type OTS owner.
I'm looking for the link to preferred vendors for carpeting, AND some guidance on the material to lay under the carpet. Can I use Dynamat as the underlayment for the carpeting in the passenger compartment?
Submitted by mr.jwhey@rocke… on Wed, 10/24/2012 - 08:04
Donald,
I used Dynamat in footwells on my S1 coupe and it did provide noticeable reduction in noise and heat levels. You'll also want some sort of felt underlayment. There are sources avail for original jute, but it's not very moisture/mildew resistant. I used a modern synthetic material. Purchased a kit on Ebay with all the pieces precut.
