July 13, 2013, 11:44 a.m. EDT
Jaguar F-Type: A sports car better than Porsche? Stories You Might Like
By Dan Neil
Dan Neil/The Wall Street Journal
Jaguar has built a car that satisfies our most refined aesthetic senses while manipulating the lowest regions of the lizard-y male mind., says Dan Neil.
We owe everything to Dr. Ing. h.c. Ferdinand Porsche. The 911 Carrera is justly regarded as the greatest sports car of all time, a fantastically well rounded, tasteful and luxurious automobile, a flawless Olympian that just keeps getting better and faster every four years. It is the standard, the reference. Mad respect for Weissach.
But. If I wanted to drop $100,000 on a sports car today, itÔÇÖd have to be the Jag. ThatÔÇÖs what we in journalism call the nut graf.
Click to Play How to spend $100k on a sports carNo offense to Porsche, but the refined yet thrilling new Jaguar may just be the best way to spend $100,000 on a sports car today, says Dan Neil.
The Jag is the new Jaguar F-TypeÔÇöI like mine with the big V8, thank youÔÇöand it is thrilling. ItÔÇÖs also a huge surprise. Personally, I didnÔÇÖt think Jaguar was prepared to go this deep into sports-performance territory with this car, which looks the part of a merely gorgeous, superbly upholstered grand tourer (the ragtop version hit the U.S. market in May, with the coupe likely arriving by yearÔÇÖs end; base engine is an also-formidable 3.0-liter supercharged V6, with either 340 or 380 hp.)
The V8 roadster with the Sport package, the V8 S ($92,000 MSRP), our test car, is essentially a factory tuner: lower, on bigger tires, and brakes with the stopping power of death rays.
If you flip the right switches, the V8 S transforms into something quite belligerent and intense, a British aristocrat well off his meds: The steering grows keen and twitchy, the adaptive suspension gets stingy, the throttle antsy, the torque-vectoring differential goes to work and pretty soon all four tires are chirping and squeaking madly around canyon hairpins. At this point, mÔÇÖlord is hauling the royal mail.
If you flip the right switches, the V8 S transforms into something quite belligerent and intense, a British aristocrat well off his meds.
And raising a royal ruckus, thanks to the JagÔÇÖs woolly exhaust note, for which it will live in noise-ordinance infamy. For some years now, Jaguar has been experimenting with engine and exhaust sounds, tuning their carsÔÇÖ exhaust systems almost musically, using a variety of actuated drums, cockpit-selectable bypass valves and silencers to evoke what they hope will be a brand-specific aural experience: deep, restrained, resonant notes at low rpm and bright, emotional notes at high rpm. Growl and purr, if you like.
With the F-Type V8 S, rabies has set in. If the carÔÇÖs active sport exhaust is set to ÔÇ£Dynamic ModeÔÇØÔÇöwhich it will be, if you possess any red blood cells at allÔÇöthe F-Type just bellows with feral, straight-pipe aggression right out of the Junior Johnson hymnal. On throttle, the superchargerÔÇÖs whine plays over the exhaustÔÇÖs whacking, resonant staccato. Off-throttle, rolling into a corner, the carÔÇÖs quad exhausts ignite in waves of snapping overrun, like firecrackers in an oil drum.
And now we have the answer to the question: What would my British luxury convertible sound like if it were entered in the B-main at Eldora?
Not sitting in one right now? Poor thing. Here are some factoids to tide you over: Our test car was the F-Type with a 5.0-liter supercharged V8 (495 hp and 460 pound-feet of torque) mounted front-midships in the all-aluminum monocoque chassis and buttoned to an absolutely stellar eight-speed automatic gearbox with paddle shifters, a transmission that could vary in demeanor from syrupy smooth to taut as a strained leash, again depending on throttle delta and where the switches are set. The same is true of F-TypeÔÇÖs torque-vectoring/limited-slip rear differential, which will allow you to dial up the tire smoke at will. You can also turn traction control off, but I didnÔÇÖt, and you shouldnÔÇÖt. You could smoke-screen a bank robbery with this car.
Click to Play Jaguar debuts new F-Type in ParisJaguar introduces its new F-Type sports car, an update of the classic E-Type, at Mus?®e Rodin in Paris on the eve of the Paris Motor Show.
The F-Type is a new product for Jaguar, and in some respects, a new business. Jag has lately made some very fast big carsÔÇöXJ, XK, XFÔÇöbut a proper compact sports coupe/convertible, a la 911? Not since the days of polio. LetÔÇÖs stop the clock at the Jaguar XK150, circa 1961. Interestingly, the F-Type is 176 inches long, within an inch of the XK150, but more than a foot wider.
The F-Type is a beaut, all right. The design of the front third of the car was heavily constrained by factors such as the size of the V-8 engine; hood height driven by pedestrian safety requirements; ventilation and cooling requirements; and accommodating JaguarÔÇÖs grille design, the down-the-road graphic. Straight on, the F-Type looks like pure appetite, or the worldÔÇÖs angriest Pok?®mon.
ItÔÇÖs the flanks that make this car. Note the sucked-in contour at the lower door ahead of the rear wheel arch; note also the eye-fooling black rocker panels (the panels under the doors) that helps control spray and manage underbody aero without compromising that athletic waist. Note the edged-blade fineness of the rear fenders and decklid. The glowering taillamps, the chrome quad tailpipes. Hello, Bishop.
The cabin is a parade of right choices: The interior is sober and coolly modern, with LED-illuminated instrumentation and grace notes of materiality, such as the nubbed-rubber-and-aluminum toggles for the climate control or the bronze-like ÔÇ£IgnisÔÇØ metal on the start button, the shifter paddles and the dynamics switch. The leather sports seats, the same as in the XKR-S, are terrific. The F-TypeÔÇÖs signature bit of drama is its powered climate vent that rises from the smooth slope of the upper dash. Too cool for school.
ThereÔÇÖs the one big go-fast switch in the gearshift console, or you can use the 5-inch touch-screen interface to dial in steering, suspension and powertrain parameters individually, though why?
Some official numbers for the F-Type V8 S Roadster: 3,671 pounds (about 300 pounds more than the comparable Porsche 911 S Cabriolet); 0-60 mph in 4.2 seconds; 186 mph top speed. Those last three metrics are practically identical to those of the Porsche. Length, width, height are within fractions of the PorscheÔÇÖs.
Stuttgart, knock knock. Candygram.
At this point IÔÇÖd ask the general reader to stand aside and let the nerds have the floor while I answer the question, HowÔÇÖs it handle? Well, again, depending on where the dynamics switches are set. ThereÔÇÖs the one big go-fast switch in the gearshift console, or you can use the 5-inch touch-screen interface to dial in steering, suspension and powertrain parameters individually, though why?
Theoretically, being a front-engine car, the F-Type should be slower to rotate in a corner than the rear-engine 911, due to F-TypeÔÇÖs distribution of mass and lower polar moment. Translation: The rear-engined car should be more nimble, more lively.
I suppose if we were to look at the telemetry for both cars around a racetrack, that might prove true, but the effect would be minimal. Modern suspension kinematics and tire design almost entirely neutralize the penalties of either front- or rear-engine layout.
In any event, the F-Type feels like it can match the 911 step for step. The front-end bites hard, the suspension composes itself instantly after initial turn-in, and the car puts a shoulder down. Midcorner, with the throttle held steady and the steering cranked, on the 20-inch Cyclone wheels and sport tires, the F-Type just rips and spits incandescently.
So Jag has built a car that satisfies our most refined aesthetic senses while manipulating the lowest regions of the lizard-y male mind. I feel so used.
And yet, IÔÇÖm somehow OK with that.
Submitted by DavidBarnes71@… on Mon, 08/12/2013 - 22:02
Clarkson did a F-type review on Top Gear. It was the supercharged V-6. He praises the performance, styling, interior and sound it makes. Negatives are high price, harsh ride at low speed and small boot. He said he was expecting the price to be in the 50,000 Pound range instead of 68,000 Pounds. I was surprised The Stig did not take it out on the track to give a comparison of it's time against the other cars on the board.
David Barnes
68 E-type FHC
Submitted by NE23-54945 on Sun, 07/28/2013 - 06:22
I think I have now seen my 20th Scion on the road in the last 4 weeks. You know the car that Jag copied. Anywho, they hit the nail on the head, the car is 26 to 32 grand, ALL in. Guess what, they were all young drivers. That's what Jag originally intended. They blew it. Im not expecting a 30 grand jag but if they stuck to their original plan and built the 60 grand coupe, They would be on top. The 100 grand + coupe/ convertable is a dead market right now.
Submitted by vineyardman68@… on Mon, 07/15/2013 - 01:29
No, not all of it, but with the F type bashing that has been going on here in the forum, I though it might clear up why there are so many comments about how Jaguar and Ian C thought they had a winner.
There are people out there who believe it is just a wonderful car, or, who get kick backs for saying so.
Either way, based on the article, I'm sure there are those who will think it's the tit's.
Garfield
Submitted by bonnettoboot@e… on Sun, 07/14/2013 - 20:49
Garfield, it seems you had the stomach to read the whole article. Not I, it was total superflous Verbage. The photo said enough. I was glad when he left the LA times where he was clearly in the pockets of the manufacturers. Touche.
Submitted by NE23-54945 on Sun, 07/14/2013 - 12:32
Not to pile on, but if anyone here gets JAGUAR WORLD in the states. A real eye opener from one of the head writers, JIM PATTEN. Most will know he has multiple etypes , marks and all the rest.
They were so excited about the FTYPE, and couldn't wait, but when they went for the test drive.........Well it kinda went down hill from there........
His wife is 5 foot 2 and was cramped, complained the ETYPE had more room!
As like her, I didn't understand the PLASTIC grab handles and the middle tunnel that's 3 feet wide?
So to add insult to injury, they award Ian C. the automobile interior design award of the year.?
Others were right, they are all cows lead to slaughter, speaking and designing what all the study groups want them to do.....
Love it or hate it, The interior of the FTYPE, is award winning? Most beautiful? New and bold?
Stop the automotive world I want to get off......
GTJOEY1314
