I need help sourcing replacement mirror glass for my '70 E-Type roadster. I can't seem to find a supplier for just the glass. Thanks in advance for your input.
Submitted by mfrank@westnet.com on Sat, 02/09/2013 - 19:28
I've not worked on the S2 OTS mirror, but the S2 coupe mirrors barely hold together. As often as not, the mirror simply falls out of the case on a hot day. The OTS mirror is different. Judging from photos, this mirror is glued in place. It should be possible for any auto glass dealer to remove the glass and cut a new one for you.
Submitted by NE40-48370 on Thu, 02/07/2013 - 05:07
This is not an easy to disassemble part with obvious fasteners. I suspect you may as well ask Champion for just six centre electrodes or Lockheed for new friction material and never mind the pad back plate.
Pete
