just noticed today that there is a pin showing at the bottom of my inside chrome driver's side door handle. also the handle feels a little loose; the other side is smooth and you can feel where there is a pin inserted from the bottom. I assume this pin goes between the upper and lower plastic part( both are intact ) of the housing which also has the seat controls, and that it is there to hold the chrome lever in place; why has it dropped down to be visible and can I fix that? I've tried to gently push it back up; or turn it and it doesn't move...don't know how or when it happened. Still opens door all right, but I figure it will break free ini time without that pin in place... any ideas?
thanks, David
1995 xjs convert.
