I tagged the wiring with painters tape during teardown but can't read the tape (brilliant, huh?) . I can't really make out the colors on this harness (runs down the left frame from the battery area, down through the triangle in the frame at the front and then ???.
First question is "Can someone identify where these go and tell me what the colors are (should be)? Maybe I can reverse engineer them with an Ohm meter or some other way.
Second, I used flex tubing to cover up old cloth wires elsewhere (see #6) and wonder if this is a good move or is there some other idea that's better?
As usual,
Many, many thanks.
