Hi, just entering the world or xk 120's and have the book "ORIGNAL XK" Restoration.
I have noted the color charts pertaining to dates in the rear of the book, but am wondering if there is a more difinative way of determining the correct color of a car. (I am hunting some down and want an orig fact respresentation.)
Is there anything on the body that should tell me? Are there any records if I prvide VIN or chassis numbers?
Thanks in advance fo the help.
Submitted by emannix@pacbell.net on Fri, 01/20/2006 - 22:23
Submitted by NE08-63766 on Fri, 01/20/2006 - 20:36
How can I tell if COLOR is correct on XK 120?
Hi Ernie,
Print out this form & when you get the info, fill it out & send it in. I believe you must be the owner, though I'm not sure. Heritage will provide the info. as to how the veh. left the factory.
http://www.jag-lovers.org/jdhtform.htm?nuc=1
Regards, Otto M.
-58 XK-150fhc, S-834292DN
Thank you very much!!!
