Submitted by f100build on Mon, 04/30/2018 - 16:42
I have a 1991 XJS 12 cylinder front crossmember that I am putting under an F100. I have purchased several front hub seals with new bearings. Unfortunately the hub grease seal is very tight. It is so tight when I install the hub the seal gets shoved inside the hub.
Just purchased a new set from Terry's Jag # CBC2858X and just tried to place it on the hub. Used a little liquid soap and it will NOT go on.
Any help would be greatly appreciated!!
