The passenger side headlight and marker light have suddenly stopped working. I have checked both bulbs and they are fine. Any suggestions of possible causes. All other lights are working fine. Thanks in advance for your help..
Submitted by pwright1@sc.rr.com on Fri, 10/04/2013 - 19:59
Submitted by dkrolik@rcn.com on Thu, 10/03/2013 - 23:18
Headlight/marker light issue 1970 OTS
Do you know if they share a common ground? If so, certainly check that and test with a temporary ground.
Submitted by NE23-54945 on Thu, 10/03/2013 - 20:47
	Push in the wiring plug on the drivers side.....make sure it isn't loose........
if that doenst work, pull the big plug and see if the contacts are clean. After that test light the sockets themselves.....good luck
gtjoey1314
Thanks for the suggestions Joseph and Day. I'll let you know how it goes..
