I thought at first that the windshield washer motor was shot. I wasn't getting anything when I push the button. No water, no sound, not even a little vibration from the motor. I took the motor out and hooked it up to the battery charger, and voila! It works! Probably just a bad connection. Then I put it back in, and no washy. Sounds from the motor but that was all. So, I went to the pet store, took the motor along, and found the aquarium air tubing fit perfectly. I got 20 feet thinking I may need it. Good thing, because just replacing the little piece on the pump didn't do it. So, I ended up replacing the whole thing. About 18 feet altogether. Ta Daa! It works! It took me a few tries to get all the crud cleaned out of the jets, but at least now I can drive in sloppy weather without the fear of having the windshield going opaque.
Also, I bought a new battery for the dash clock on Amazon and it works great. I assume since it works it must not have been used much in its past life, as that is apparently one item that doesn't usually survive long.
My next project is to try to figure out why the air conditioner is nonfunctional. When I turn the blower switch, nothing happens. I cannot find any fuse for that circuit, so maybe it's the relay?
69 2+2 4 speed manual with factory air
