I have a 1997 XJ6L and the gas pedal has started to grab at the initial contact and then frees up. This causes the car to jump when you accelerate since I have to press harder to get the pedal to get past the grabbing point. Any suggestions?
Thanks alot!
Sincerely,
Patrick Brennan
Submitted by pascal@jcna.com on Fri, 10/21/2005 - 15:54
dirty / sticky throttle body. known issue / routine mainteance. needs to be cleaned up. a rag with carb cleaner shoudl work but be careful not to contaminate the throttle position sensor.
Pascal Gademer
