NEED TO LOCATE FUEL "T" CONNECTION BETWEEN DUAL CARBARATORS FOR A 1968 JAGUAR XK E type
ÔÇ£TÔÇØ FUEL CONNECTION BETWEEN CARBURETTORS:
Molded nylon (probably polyethylene) ÔÇ£TÔÇØ with a metal pipe embedded in the bottom (Part No. C.28915)
CALL FRANK SHAFFER (318) 636-4111, E MAIL: frsezonline.com
![](https://www.jcna.com/sites/default/files/2719686124453.jpg)
Submitted by dale@ls.net on Tue, 05/11/2010 - 22:10
Frank, if you find that tee connection, let me know. I need one also. My carbs have a
tee with two pieces of fuel hose connected with four "C" clamps which is a combination
available from most auto parts stores. Not a good solution. In your picture I hope that
bottom fitting is threaded into the tee with thread sealer. I see also that the bottom
fuel hose is press fit to he fitting. It would be a good idea to put a clamp there.
