I understand that if you disconnect the sender in the upper gas tank altogether and connect on the sender in the lower gas tank to the gas gauge, then this results in a full reading for the first 14 gallons after a fillup and then linearly drop from Full to Empty as the 11 gallons in the lower tank are consumed. I would like to disconnect the sender in the upper tank. Does anyone know where it is located and how it is disconnected? Thanks much
John Salla jsalla007gmail.com
Submitted by SE98-32482CJ on Wed, 08/25/2010 - 08:25
John it is under the carpet on the shelf behind the seats.
