I need to take out the last of the components in front of the engine. They are:
Anti-sway bar
Shocks
Upper & Lower Wishbones
Power Steering Rack
Since certain things are attached to others (shocks and sway bar to wishbones) and different "jacking requirements" to remove different things, is there any sequence that works better than others?
For instance, removing the shock requires having a jack under the lower wishbone near where the shock is attached, but once the shock is removed, it seems the bolt that secured the shock to the arm is now loose/unconnected and might be unstable when jacking up the car in a different place to remove other components.
Hope this makes sense.
Thanks.
Tony
