I have 1970 XKE 2+2 coup. I have taken off my front brakes and want to replace the dust covers and cylinder brake seals. I have forgotten how to get the 3 brake cylinders out of their homes. Does any one know?
Your assistance is appreciated.
Submitted by joshbartlett@r… on Thu, 03/24/2016 - 07:16
If you mean the removal of the caliper pistons, one method is to use air pressure into the opened bleeder - holding the pistons progressively until they can all be removed by hand. Another method uses the brake pedal pressure with the calipers still attached - this is messy and requires an assistant. Either way, be careful! The pistons can come out with some force.
