This concerns a 1968 E-type FHC. Would anyone know the original color of the RH and LH stoneguards located on each side of the engine? They attach to the bottom of the engine frame and are parallel to the ground. The RH one is just below the oil filter. Also, were they originally made of steel or aluminum ? Thank you.
