I am original owner of a 64"E" coupe with a 3.77 rear end ratio. This car was very fast. At the high speed the car flattens out and sort of hesitates and ocassionally coughs. I have checked / replaced all the things you can think of. Replaced a new SU fuel pump etc.The distributor is original, todate I have not replaced it, however I obtained a new Petronix complete distributor ready for installation. The C.R ratio is about 155 psi in all 6 cylinders.
Please any ideas.
Submitted by SE98-32482CJ on Thu, 10/22/2009 - 11:52
Submitted by SC37-20181J on Thu, 10/22/2009 - 08:27
Re.: engine missing at high RPM
could be a bad coil, Had two in the shop with the issue this month
Submitted by wcjssj@comcast.net on Mon, 10/19/2009 - 12:23
Edited on 2009-10-19 12:37:11
Edward, the complete air filter system must be installed, or at high speeds you will have the problem you describe because of turbulance in the carbs.
Curt
Submitted by SC38-21185J on Mon, 10/19/2009 - 09:47
Like Mr. Brady says, it's probably timing. Make sure the rubber boot at the vacuum advance on the dist. is making a good seal. I would probably start with a fresh set of plugs too, couldn't hurt.
Submitted by edjagm@comcast.net on Mon, 10/19/2009 - 09:31
THANK YOU FELLOWS FOR RESPONDING. I HAVE REMOVED THE AIR FILTER COMPLETELY. THE CARBS ARE OPEN. INTERESTING,. I BELIEVE THE PLUGS ARE GAPPED AT .025.
Submitted by SE98-32482CJ on Mon, 10/19/2009 - 08:26
Curtis you are correct but perhaps we need to ask what type of air filter he has.
Submitted by wcjssj@comcast.net on Sun, 10/18/2009 - 23:55
Hi Edward
Are your plugs gapped to 0.025"? Is your air filter completely installed?
good luck
Curt
Submitted by bonnettoboot@e… on Sun, 10/18/2009 - 15:51
Edward is so correct--I have "fixed" many cars by simply removing "Boy Racer" air filters and replacing them with the stock system.
