Hi everyone,
I have a XJ6 96. The misfire during idle and low RPM has been a problem but the check engine light did not come out. Today it came out as for cylinder 4, and I will be replacing the ignition coil first to see if that fixes it.
However, they were two more codes which I got from the code list:
B1315 Battery Saver Relay Coil Circuit Short To Battery
B1316 Battery Saver Relay Coil Circuit Short To Ground
Everyone I asked seemed to have no idea what those are, can someone please help me? I would really appreciate it!! Thanks!!!
