Looking for part # CO32567 (left hand door switch installed on 1969 and later E-type 2+2 models) without much success.
The black plastic switch has 2 spade connects and a bullet-ended red ground wire. The switch is screwed into a small metal plate which is then 2-screwed into the door jam.
Is there another switch option if this is an unavailable/discontinued part?
The right hand door jam switch is a standard metal switch (readily available), threaded directly into the door jam. A single bullet coupler attaches a single (purple/white) wire to the end of the metal switch.
If I purchase the metal door jam switch for the left side, some modification is necessary to both wiring and mounting.
Can help help with this modification or have another switch suggestion (like an early XJ6 switch) that might work?
Thank you!
