Car is a Series II 2+2
Owner wants to avoid disassembling the door if at all possible.
Question:
Is it possible to replace the door glass in this car without removing the window frame from the car. I know how to separate the glass from the channel it sits in without removing that channel. Once I separate the glass from that channel is there a way to maneuver the glass out of the door with the window frame still attached to the door?
Best Regards, John
Submitted by georgejones123… on Mon, 08/28/2006 - 14:56
John,
There is absolutely no possible way to remove door glass without taking the frame out!!!
George Jones
Private Restorer.66' 3.8 Mark 2, 67' Ser. 1 FHC "E"
