I am in the process of replacing the dash wire loom. I am not restoring the car but I was able to remove the dash board top, odo, tac, and a bunch of other things to have better access and put the loom in.
I am at a point where I need help.
1- I do not know how to get into the door to connect the purple/white door light switch. Do I remove the whole door or is there an easier way?
2- There is a red/white cloth wrapped wire that goes to the starter I believe. How do I get to the starter? From under the care or remove the air filter to get it.
I can send pictures if that helps.
