I may be purchasing a 1970 XKE roadster in the next week or two. What is the correct or best tire size for this car? Any brands that you folks recommend or to stay away from? This car has its original wire wheels and I know that inner tubes will be needed. Anything I need to know about purchasing them or what to tell the people who are doing the installation? Is it possible to put tires on the original rims without inner tubes?
Submitted by john.walker@sh… on Thu, 09/14/2006 - 08:53
Yes, the stock wire wheels are not sealed for tubeless tires. The iar woule escape where the nipples pass through the rim. You need tubes, be sure to buy quality tubes and also you need the rubber strip that goes between the nipple ends and the tube. Otherwise you will most likely have premature tube failure.
Best Regards, John
