OOO NO!!!! rear windows(small) stuck in the down position too.Top will not go up or down and no noise from the motor...was told to replace the fuse,but I can NOT find the fuse! Any comments before I go to the $$$$$dealer? TKS.......Pete
Submitted by michel@dinomar… on Wed, 02/06/2008 - 16:25
Peter,
The hood fuse, is light green, 30A and located on a bracket adjacent to the pump motor in the rear stowage compartment, if you have a two seater like mine it is inside the rear box on the right side. There is a cover over the pump.
Michel
Submitted by michel@dinomar… on Wed, 02/06/2008 - 16:09
Hello Peter,
You can switch the hydraulic to manual if you need to move the top up, it is in the owner book and very simple to do. I am looking for my shop manual to find out where the fuse is.
Michel
1994 XJS
