Sometimes when I turn the ignition nothing happens. If I wiggle the shifter in park it starts immediately. How can I fix this problem.
1995 XJ12
Submitted by jdiadanza@comc… on Sun, 06/24/2007 - 21:07
Service and Repair
sounds like the Neutral Safety Switch The directions below are for a 94XJ12 Basically should be the same
Disconnect battery ground cable.
Remove gear shift knob and console.
Remove neutral safety switch retaining screws and hold switch to one side.
Disconnect cable harness block connector, then remove switch assembly.
Position new switch in neutral, then attach new switch. Do not tighten screws.
Position setting gauge JD 127 between switch and console panel. Ensure slot is positioned over pin of neutral switch.
Tighten retaining screws and remove gauge. Move selector lever to ensure each position indication is correct.
Ensure vehicle will start with switch in park and neutral positions.
Replace console and selector knob.
